OK i dropped in my 4mill FAST motor today....had everything ready but no race gas..... So My buddy said he had a half a can of VP C12, i was like cool bring it....
Mixed up a gal and kicked until leg was about fall off, checked spark...fine, then poured some of the gas on concrete, and voila, condensation/water in the gas.... and a good bit. So i dumped tank, rinsed with reg gas, took apart carbs and blasted them.... Did i hurt anything in the motor as long as I didnt run it? Also for those that run race gas do yall use c12 on 2 strokes? ive always used it on my streetbikes, just wondering what everyone uses.... Thank
Thanks for your reply. Yea I was just wondering. I mean it's a new motor, never been ran just nervous I guess. Just wanted to make sure water wouldn't hurt nothing internally.
Wont hurt anything, unless you let the watery gas sit down on the crank and bearings for a good long while , but im sure you wouldn't do that. Fresh gas and your golden.
don't worry, i get water all the time, both from running through creeks and washing/overnight condensation from washing....i drain the carbs once in a while, and call it good. worst thing it's ever done is sticky slides, or ice in the carbs. i've seen my plugs completely drenched, wiped them off, fired it up and just blew it away, no porblems. only thing is if you had more than a couple cups sitting in the engine
Appreciate it fellas....Gotta fresh new 5gal drum of c12 coming today, gonna go ahead n clean her out, real good hahaha......shouldve went with pump domes though, this is gonna get expensive..... $75!!!!!!!!! WTF!
Do you have a sunocco dealer anywhere near you? I get 110 for 6.75 gallon in 55 gallon drums, or 112 for around 8.50 save 10 cents per gallon if you buy it in the 55 gallon drum, and with 2 shees on race fuel that doesnt last too long
can ou get away with 100oct? if so, look for avgas. i buy it @ the pump for little more than premium @ one of those card stations that sell just regular and diesel by card
Depending on your compression you may be able to get away with a 50/50 mix. I pay $63 for a 5gal can of C12 and get 5gal of premium pump gas and end up with 10gal of approximately 103 octane for less than 8 bucks a gal.
I do need to get in Touch with Jeff and find out. I wouldn't mind at all if I could do 50/50. Or run av gas. There's a pump at the municipal airport that sells it but they don't like to sell to public for some reason. Gotta know somebody that know somebody if u know what I mean.
you should look into e85 ethanol corn fuel if you have it out by you it should be less than $2 a gal and if im not mistaken its the same as c12
What size domes did Jeff set you up with? My 4mil i just got from him, he set me up with 19cc domes. Assuming he set you up the same, I dont think you are going to run 50/50 with that. UCCR is around 16:1 Assuming your elevation is aroung sea level or close, and squish is normal, i just dont see you mixing fuel especially with timing at +7 s in your sig
I have 19cc domes as well, .018 base gasket if i remember correctly,(ill have to check reciept when i get home). .046 squish, Sea level-200ft and timing is at +7, thats where Jeff set it at and said that he wanted it, im running straight VP c12 in it @ 32:1.......... I checked compression on a cold never started motor and it was 150psi.....guage may be boogered? about right?, its a Oreillie's guage but its a nice one.... i dont know, I have a issue going on right now that i need to get in touch with Jeff about, more on that soon........
From the sound of it you have the same setup as me, but my elevation is around 2,000. So yeah your gonna need to run race fuel, i know i have too.
C12 has a Motor ocatane number, thats the octane number you need to look for, of 108. VP110 has a motor octane number of 107, thats what i use.
Well I got her purring like a kitten. Heat cycled it a few times and been putting around the years going through the gears. Has a bad bog off idle. I'm sure that my airscrews tho. Just got a little tuning to do. Thanks again everyone.
