So I went ahead and split my case today to replace all theseals. I was putting back together on my bench. I put a vitos clutch in so I am assuming the just go anyway cause the steel plates don't have no markings. Then I put the rod and ball back in put the pressure plate and screws/springs back on and then when I pulled the bracket where the clutch cable goes in it will pull but the pressure plate doesn't open. Isn't it supposed to open when u pull clutch. I tried adjust the screw too but any further in I can't pull on the clutch bracket
Are you sure you lined up the pressure plate with the arrow on the inner hub? There is only one way that critter can go.. Other ways will not go on all the way and the tell tail sign is slack in the push rod.
Brandon
Mull Engineering
Yeah I got three arrows on mine used middle one. If I screw the pusher in all the way then it's too far and I can move clutch assembly. Then I can't get a medium on it. Is the plate suppose to pull away when u hit the clutch
i got the plate to work when its not screwed down just when i hold it there with my hand but when i torque it down to the i believe it was 7lbs the plate doesnt wanna pull away.. plate is flush with last friction plate
Somethings not right ! you got both the spacers for the basket back in right ? the plate will pull away but not much .
