Thinking about buying the dyna tek FS Ignition for my 97 drag banshee (4 mil stroker LA Sleeve Top end fresh pistons sleeves ect drag ported 4 spd override 36mm PWK carbs CPI out of frame drag pipes) Bike is set up for 1/8 mile asphalt and 300' sand drags (Change gearing tires and wheely bar setup) Was hoping to get alittle more out of it with this ingnition and some of its functions anyone use the launch limiter?? And the rpm activated outputs? Also most say it takes dyno tuning the take full potential thats not an issue local cycle shop has a dyno I can tune with is tuning with their software fairly straight forward? Does it replace the original CDI?? Hoping it does and I could use cdi from that bike on my yfz/ banshee hybrid
Thanks
Evan
Thanks
Evan
It replaces the stock CDI. The software is very easy to use. I have used the launch limiter function. I broke my reeds with it; but it worked like it should.
How did it break your reeds? Not looking to use it if its going to hurt the bike just to make the bike deadly consistant off the line. Think I am going to grab on this winter and see what I can do with it.
The launch limiter crawled out of his cdi box with a little hammer and slipped into the intake, then it was on like mario bros with the reeds and the little hammer.
