krauss4 Posted October 5, 2009 Report Share Posted October 5, 2009 i bought a 4 mill banshee how do i know that i have a 4 nill crank in it? any thing obvious? Quote Link to comment Share on other sites More sharing options...
sToCk7miLL Posted October 5, 2009 Report Share Posted October 5, 2009 i bought a 4 mill banshee how do i know that i have a 4 nill crank in it? any thing obvious? Either take the cylinders off check the numbers on the rods... OR take the head off and turn the bike over until the piston sticks out of the cylinder the farthest, get a micromiter and measure it Quote Link to comment Share on other sites More sharing options...
crustydemon Posted October 5, 2009 Report Share Posted October 5, 2009 i bought a 4 mill banshee how do i know that i have a 4 nill crank in it? any thing obvious? So you think you bought a 4 mill banshee? Pull the head off and see if the pistons comes up out of the jugs when at TDC(2 mill) or if there is a spacer plate between the bottom of the jugs and the case you know it is without pulling the head. Quote Link to comment Share on other sites More sharing options...
kodie Posted October 5, 2009 Report Share Posted October 5, 2009 yep easiest way is to check for a spacer plate if none than pull the head off and push your kick lever down till your piston is at tdc like said above and it should stick out overtop your cylinders 2mm. Also the domes on my 4mil said 4mil 21cc etched on the side of them. So you could check the domes to see if they say anything about 4mil (xx)cc domes. Quote Link to comment Share on other sites More sharing options...
