ramnation Posted September 16, 2009 Report Posted September 16, 2009 I just bought another banshee, its a 98. it needed a new top end. I got a stock top end for it and put it back together. It ran alright for a short period of time. it idles high and it seemed the carbs stuck open after a WOT run but it would idle back down. Now it sounds like its missing, really loud pinging and popping out of the left cylinder. LOTS of smoke out of that cylinder. Anyone have any advice would help. Thanks in advanced.oh btw it has fmf pipes and reeds but is jetted for them already. Quote
ramnation Posted September 16, 2009 Author Report Posted September 16, 2009 I just bought another banshee, its a 98. it needed a new top end. I got a stock top end for it and put it back together. It ran alright for a short period of time. it idles high and it seemed the carbs stuck open after a WOT run but it would idle back down. Now it sounds like its missing, really loud pinging and popping out of the left cylinder. LOTS of smoke out of that cylinder. Anyone have any advice would help. Thanks in advanced.oh btw it has fmf pipes and reeds but is jetted for them already. ok quick update. My brother switched the plugs and it made the other side (right side) misfire. put in a new plug and it works great but it still has a slight loss of power and still smokes like crazy out of the left side. Quote
pr0blumz Posted September 16, 2009 Report Posted September 16, 2009 ok quick update. My brother switched the plugs and it made the other side (right side) misfire. put in a new plug and it works great but it still has a slight loss of power and still smokes like crazy out of the left side. Did you do a leakdown test after doing the top end? Did you sync the carbs? What are your mods? What mains are you using? Quote
ramnation Posted September 16, 2009 Author Report Posted September 16, 2009 Ok its fine now. Found a loose boot and the part on top of the left carb was loose. thanks Quote
