Prices are shipped, US and Paypal only
(Elkas, and YFZ shocks not for sale)
Pics will be posted as I break it down and more parts sell Or just PMwhat you need to see.
Cylinders - HJR Full Dune Port fresh bore, hone, with wiseco pistons wrist pins and bearings (64.5 bore, 10hrs on topend) = 625
Noss Billet Cool Head w/20cc domes (has FAST RACING on the top of it) = 170
Bottom end - never split, F.A.S.T Clutch, Case saver, +4 Ricky S Timing Plate, stock stator and flywheel, Pancake Bearing, 1 bolt hole broken by the sprocket from over tightening the stator cover, it does not effect it. = (400 range....(I will need to check shipping cost for final price)
Chromed (not polished) Clutch Cover - billet impeller with new bearing and seals, Cascade PC gloss black water cover, and chrome insert = 160
FMF Fatty's w/PC2's (nice) = 225
Polished 28mm Keihin Pwks Carbs = 200 (sold)
KN Pods with brand new Outerwear's (used on my 28mm carbs, has a 49mm outlet) = 50
Billet Duncan 2pc Stator cover w/extra chain covers = 160 (sold)
Chrome Kicker = 25 (sold)
VForce 3 Reeds = 150
Billet reed spacers = 20 (sold)
+2 StrongArm A-Arms complete w/hubs, spindles, rotors, and tierods (bolt on and go) = 425
+2 Swingarm stock style = 160
Rear stock shock (very new, great shape) = 80
Billet Adjustable Shock Linkage = 10
ProTaper SE bars with ODI lock-on rouge grips = 70 (sold)
ASV F3 brake and clutch levers = 60 (sold)
AC Blackline Propegs Nerf Bars (great shape, no bends or dings) = 225
Billet Prodesign shifter PC gloss black = 30
PRM front Summit bumper pc gloss black = 70
PRM rear grab bar pc gloss black = 45
Powder coated gloss black accessory parts: Rear Rezi cover, Pipe clamps, and Bar Clamp = 60 (sold)
Harness loom w/kill tether, no key, square plug, 98ish= 50
CDI = 60
Chariot billet timing plate w/mint stator = 100
gas tank - very nice, good petcock, brand new cap = 45
Stock Air box with vented lid = 40
Thumb Throttle = 20
Clutch Cable = 15
Frame = 100 (sold)
2 Coil's = 20 each
Billet sprocket hub (not sure brand, looks like the LoneStar, not in pics) = 60
Bump for a awesome dude. And some killer parts. I cant believe no one has picked up those HJR Cyl yet. If any of you guys are looking and debating. I must say.. Buy them. Insane upgrade for power on your shee.
Thanks bro. I will be adding more pics of everything this weekend. Here are a few.
Updated List
Bad Ass HJR Cylinders and pistons - HJR Full Dune Port fresh bore, hone, with wiseco pistons wrist pins and bearings (64.5 bore, 10hrs on topend) = 625
Bottom end - never split, F.A.S.T Clutch, Case saver, +4 Ricky S Timing Plate, stock stator and flywheel, Pancake Bearing, 1 bolt hole broken by the sprocket from over tightening the stator cover, it does not effect it. = (400 range....(I will need to check shipping cost for final price, will break apart later if I have enough offers for the parts)
Polished 28mm Keihin Pwks Carbs JJH needles, new bowl orings and top gaskets = 200
VForce 3 Reeds (great shape)= 150
Stock CDI = 60
Stock Air box with foam vented lid = 40
Thumb Throttle = 20
Clutch Cable = 15
Billet sprocket hub w/sprocket (not sure brand, looks like the LoneStar, not in pics) = 60
