bp12 Posted September 2, 2009 Report Posted September 2, 2009 hi i got a 99 banshee and need to know how to sync the carbs i undid a carb to check float and put it back together now it wont idle runs fine when opened up Quote
TurboBanshee420 Posted September 2, 2009 Report Posted September 2, 2009 http://www.farmandsandtoys.com/partdetail.asp?partid=59 good buy! Quote
first shee Posted September 3, 2009 Report Posted September 3, 2009 couple videos on Youtube on how to sync your carbs Quote
Driggs Posted September 3, 2009 Report Posted September 3, 2009 Does it have the TORS still on the carbs? If not, I take my filter off and put one finger on each throttle valve and feel which one is slow to open when I press the throttle. Then I adjust the nut on the carb caps. Much better to order the sync tool but it gets it close. Quote
bp12 Posted September 3, 2009 Author Report Posted September 3, 2009 hi i got a 99 banshee and need to know how to sync the carbs i undid a carb to check float and put it back together now it wont idle runs fine when opened up got it pretty close by eyeballing but still idles hi . should i let it warm up first Quote
Michael66 Posted September 3, 2009 Report Posted September 3, 2009 adjust it at the thumb throttle now Quote
stokes77 Posted September 4, 2009 Report Posted September 4, 2009 Got the crossover tube connected? Quote
bp12 Posted September 4, 2009 Author Report Posted September 4, 2009 adjust it at the thumb throttle now Quote
bp12 Posted September 5, 2009 Author Report Posted September 5, 2009 yes cross tube still connected Quote
bp12 Posted September 5, 2009 Author Report Posted September 5, 2009 hi i got a 99 banshee and need to know how to sync the carbs i undid a carb to check float and put it back together now it wont idle runs fine when opened up took it out and ran it today and ran good for the most part then it started to back fire but once revved up it was fine Quote
