SLOPOKE21 Posted August 30, 2009 Report Posted August 30, 2009 i have an 03 banshee with dmc pipes reed spacers k&n pods and timing advanced +4. i was wanting to upgrade my carbs but dont know which specific type or size to go with. so if someone could explain the different types or give their recomendations it would help out tons. Quote
Havok248 Posted August 31, 2009 Report Posted August 31, 2009 i have an 03 banshee with dmc pipes reed spacers k&n pods and timing advanced +4. i was wanting to upgrade my carbs but dont know which specific type or size to go with. so if someone could explain the different types or give their recomendations it would help out tons. With the setup you have now the stock carbs are sufficient, it would be a waste to go to bigger carbs unless your going to port your motor Quote
Drewski Posted September 1, 2009 Report Posted September 1, 2009 i heard good stuff about the pj d slides i think there called (30mm) and they come pre jetted for your machine and they also give you jets 1 size up and down and i think they are 300 bucks on flea bay. thats my next mod Quote
Titan up Posted September 1, 2009 Report Posted September 1, 2009 I'd keep the stock carbs. Just remove the tors if you haven't already. Stock carbs are under rated they will flow up to 65-70 horsepower. Quote
