This is what happened, Riding down the road just when i really started to open it up, it sounded like i ran out of gas. Stop and look gas is flowing out of the carbs non stop. Take the bike home adjust the floats clean the carbs and it will barely start and when it does it will NOT rev at all. Carbs are synced compression is perfect dont know what to do next it was working fine. will having too big a fuel line be some what of a problem?its 1/4 inch inside diameter and i can see a small air bubble in the line all the time. any help would be great
im not sure if too big of a fuel line would cause this but it sounds like it is flooding out you may want to try and go back to the stock size line and see if that helps any carbs are a pain in the azz though so good luck
Thats just stupid talk. Carbs are simple. :ph34r:
