Building my First Posted August 20, 2009 Report Posted August 20, 2009 Finally got around to checking my squish. Mods are in my sig. Base gasket measures .024", I see most guys say between .035 & .050. Can I get a thinner base gasket or will I be fine? Squish is even on both sides of both pistons. Quote
Snopczynski Posted August 20, 2009 Report Posted August 20, 2009 I would get it down to at least .050"! You could even run it at .045" with the rpm that motor would pull. When the squish is to big, I have seen them run really funny (hesitations). Quote
Building my First Posted August 20, 2009 Author Report Posted August 20, 2009 Do you know where I could get a .010 base gasket? Quote
Building my First Posted August 20, 2009 Author Report Posted August 20, 2009 Those carbs I traded for ended up being 28mm, he can't use a tape measure very well. Quote
Snopczynski Posted August 20, 2009 Report Posted August 20, 2009 Do you know where I could get a .010 base gasket? Cascade innovations sells a .012" steel I think. Anyone ought to be able to get one. Quote
SAVAGE420 Posted August 20, 2009 Report Posted August 20, 2009 Those carbs I traded for ended up being 28mm, he can't use a tape measure very well. LOL, you should have made sure about that then :thumbsup: Quote
Building my First Posted August 20, 2009 Author Report Posted August 20, 2009 28mm is what I really needed for my mods. I wasn't going to pass up some 33's when he mentioned trding them for stock carbs. Quote
SAVAGE420 Posted August 20, 2009 Report Posted August 20, 2009 28mm is what I really needed for my mods. I wasn't going to pass up some 33's when he mentioned trding them for stock carbs. True. :thumbsup: There pwk's though? Quote
bbcmudtruck Posted August 20, 2009 Report Posted August 20, 2009 I have a couple of different cut thicknesses paper gaskets I could hook you up with. What thickness are you currently using? Quote
Building my First Posted August 20, 2009 Author Report Posted August 20, 2009 Yea, there PWK's. The base gasket thats in there now is .024". Quote
Darthwall Posted August 20, 2009 Report Posted August 20, 2009 Yea, there PWK's. The base gasket thats in there now is .024". there is a guy on ebay that sells them and vito's has them in a .012 Quote
mopar1rules Posted August 21, 2009 Report Posted August 21, 2009 i thought vitos has some too.......X2 on getting the squish down to at least .050". Quote
