fmf gold series
280 mains
27.5 pilots
My bike runs great at all throttle but at idle it seems to cut out. When i pull the choke 1/2 it brings it back up. Im thinking im lean, but not sure what to go up on, pilots, mains, etc It seems to only cut out on one side also.
Any help would be great, thanks.
fmf gold series
280 mains
27.5 pilots
May want to check pilots one could be clogged, you should be fine with the jetting you have. Have you adjusted the a/f screws? Screw in and lightly seat them and back out 1.25 - 1.5 out.
Oh yeah, nice chevy!
I have taken the carbs out several times to check if its clogged. Always spray them out. I have not yet messed with the air screws, ill give that a try after work.
Thanks
Start at 1.5 turns then work your way from there . tighter is richer , looseing is lean , If that dont work you may need to go up one size. :cool:
