mofoka Posted August 16, 2009 Report Posted August 16, 2009 please post up asap I'm guessing it's a choke tube of some sort.... what does it do? I wan't to know if it is something I NEED or want. THanks mang Carb #1 has it but carb #2 doesn't Quote
Rodneya Posted August 16, 2009 Report Posted August 16, 2009 Choke tube. It goes into jet in the bowl. that is why you cant mix up the carb bowls. Quote
mofoka Posted August 17, 2009 Author Report Posted August 17, 2009 Choke tube. It goes into jet in the bowl. that is why you cant mix up the carb bowls. Ok. Then it is only supposed to be in one bowl? Or do I need to buy one for my second carb? Quote
pr0blumz Posted August 17, 2009 Report Posted August 17, 2009 Ok. Then it is only supposed to be in one bowl? Or do I need to buy one for my second carb? No, you don't need to buy another bowl. Its for the choke and only one of your stock carbs have a choke. Just remember to connect the choke tube between the two carbs when you put them back on the bike. Quote
mofoka Posted August 17, 2009 Author Report Posted August 17, 2009 That's sweet, I won't bother picking up a tube for carb #2 then. Thanks again Quote
AKheathen Posted August 17, 2009 Report Posted August 17, 2009 don't forget to check which bowl you put on that carb. you need the one with the choke jet in it. there is a little brass bead on the outside of that bowl Quote
mofoka Posted August 18, 2009 Author Report Posted August 18, 2009 Thanks guys! No problems putting it back together..... I always assumed that they where two identical carbs. I guess you learn something new everyday. Quote
