crazycanuck Posted August 9, 2009 Report Posted August 9, 2009 just finished instaling my shearer's and they fit and look great! after a washer here and washer there, evrything lined up perfect. anyways how are they for leaking after time, do any of you use 2 o rings At the cylinder? thanx. Quote
rb0804 Posted August 9, 2009 Report Posted August 9, 2009 just finished instaling my shearer's and they fit and look great! after a washer here and washer there, evrything lined up perfect. anyways how are they for leaking after time, do any of you use 2 o rings At the cylinder? thanx. there should be an oring in each pipe. They do not come from Matt with them in there you have to locate and install them yourself. Quote
RZBansheeMan Posted August 9, 2009 Report Posted August 9, 2009 Just pulled the stock O-rings out from my stock pipes cleaned them up and intalled them into my Rockets, they don't leak. Quote
crazycanuck Posted August 9, 2009 Author Report Posted August 9, 2009 ya i got the pipes from jeff @ F.A.S.T and they came with the high temp o rings just wondered if anyone had any tricks for a fool proof seal. Quote
