i got all new electrics. so i actually have spark now. and she can start on the first kick. i was driving it around the other day after throwing the carbs back on for the third time. and it didnt really seem to have any power.
im in minnesota elevation is 1000 ft i believe. i have pro circuit platinum pipes and a k&n filter. boyesen reeds. i have 310 mains. after asking last year someone told me to go 310. think every other jet is stock. i will have to check.
the main problem is i go out today and start her up and im having the same problem i had last year. its revving like crazy with no throttle on and the slides arent stuck. what would cause all the fuel to get into the cylinders when its sitting. how can i check for air leaks? with starting fluid? or carb cleaner?
also one of my reeds the petal is spaces out ever so slightly, are they worn out and would bad reeds cause this?
does that have anything to do with my jetting? because she didnt seem to have any power a few days ago.
Edited by Dan
