old roost Posted August 6, 2009 Report Posted August 6, 2009 (edited) is it bad for then engine and why??? um i am just saying if i can feel air coming from the bottom of the jug it must be leaking but my ? was would that cause it to sputter and all that if it is losing compression yes it is bad, see what black sunshine posted, it can cause a lean condition, to much air and not enough fuel, the banshee 2 stroke engine relies on the oil mixed in the fuel for lubrication in the cyl's, if you are running lean it is not lubricating properly and bad things can happen. and yes a gasket/ air leak can cause an engine to sputter wether it be a 2 stroke or 4 stroke. Edited August 6, 2009 by old roost Quote
yamahaman244 Posted August 6, 2009 Author Report Posted August 6, 2009 yes it is bad, see what black sunshine posted, it can cause a lean condition, to much air and not enough fuel, the banshee 2 stroke engine relies on the oil mixed in the fuel for lubrication in the cyl's, if you are running lean it is not lubricating properly and bad things can happen. and yes a gasket/ air leak can cause an engine to sputter wether it be a 2 stroke or 4 stroke. Allright thanks because when I started it sputters and kinds backfires so I think it is the base gasket Quote
yamahaman244 Posted August 6, 2009 Author Report Posted August 6, 2009 Allright thanks because when I started it sputters and kinds backfires so I think it is the base gasket Anyone else and were is the cheapest place to get piston kits Quote
