I've used them. The reason they're used is to help with some turbulance issues associated with the factory round style stuffer when used with aftermarket intakes that have square openings. You want the intake tract to flow flow as smoothly has possible. So the cascade stuffers allow people with certain intakes to match up the intakes without porting the factory stuffers.
i ran them and to tell you how big of a difference, i can't say,but i'd say they are worth the money if you are running 39mm or larger carbs
Yes. Without them...nothing holds the VForce 3 in place.
I agree with fouled out...if you have larger square holes in your intake, get the cascade stuffers.
If you have smaller, stockish holes for your intake...there's not much point.
