if it pulling right is it worse with front tires on ground or wheeling ?
if worse with tires on ground may be a caster problem check a arms and mounts real close.
If worse when wheeling check for loose swingarm bushings or bad axle carrier bearings also if stock carrier make sure it is adjusted right (axle square with frame)
First check all tire presure and sizes
