bennieben1 Posted July 14, 2009 Report Posted July 14, 2009 i weigh 330 lbs. i normally use 4 lbs. up front and rear. if im using aftermarket more ply tires. i use this for trails and rocky terrain. if im using stock tires i put 5 lbs front and back or else, kaboom, popped, punctured :biggrin: Quote
locogato11283 Posted July 14, 2009 Report Posted July 14, 2009 i run with 10psi back in my holeshot mxr4!! 19x10-10!!! why? Quote
Hulio-mv Posted July 14, 2009 Report Posted July 14, 2009 http://www.goldenwestcycle.com/productinfo..._676-dc_587.htm I have been using these for chadwick and other rocky conditions with 5 or 6 psi also on the raptor at the dunes a buddy broke his bike and rode the raptor with them on it I am not saying they are paddles but they worked ok Quote
peterlocal22 Posted July 14, 2009 Report Posted July 14, 2009 (edited) thats because razrs are fuckin junk.. let me know when youre ready for new tires and ill get you lined up with something thats not overpriced and worthless. i would stick to about 4 psi in the trails. things like rocks, hard corners, tree roots and stumps can pop tires off the bead.. id play it safe with around 4 or 5. +1 on tire pressure i ran lower and paid the price Edited July 14, 2009 by peterlocal22 Quote
Angel ripper Posted July 14, 2009 Report Posted July 14, 2009 maxxis tires with around 4-5 pounds in the rear and about 4 in the front, I run GNCC and that will get you over without being a rough ride or worring about comming off a bead if you don't have beadlocks the stock yfz tires are a great choice for trails, they hook up great, on everthing from muddy trails to sand but they wear very quickly and roll too much in turns Quote
