Thewhite Posted July 6, 2009 Report Share Posted July 6, 2009 Im wondering if someone have ever change a cylinder stud (to mount the cylinder on the case). One of the thread is dammage and Im not able to remove the stud. I tried to heat the stud with a torch but the stud bent. Any help will help ... can I place the case in the oven at 325 deg F and them try to remove the stud !! Quote Link to comment Share on other sites More sharing options...
someone82 Posted July 6, 2009 Report Share Posted July 6, 2009 Im wondering if someone have ever change a cylinder stud (to mount the cylinder on the case). One of the thread is dammage and Im not able to remove the stud. I tried to heat the stud with a torch but the stud bent. Any help will help ... can I place the case in the oven at 325 deg F and them try to remove the stud !! Did you try a stud extractor, they work like a charm. Soak it over night with some good penatrating lube. Seeing you bent the stud you got it too hot. Quote Link to comment Share on other sites More sharing options...
Drewski Posted July 7, 2009 Report Share Posted July 7, 2009 well i'm not sure how your going to get that stud off now but I always double nut them off, it works great ! Quote Link to comment Share on other sites More sharing options...
shee rips Posted July 8, 2009 Report Share Posted July 8, 2009 in that case heating it was the wrong thing to do. one, heating it expands the metal, tightening the fit. getting it hot then quenching works though. two, you got it hot enough to get soft. andyways, a pipe wrench often works. if the double nut trick is good when you plan on reusing the stud. you can also buy tools for it that work like a charm Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 8, 2009 Report Share Posted July 8, 2009 Heat the stud up, press a candle to it, any kind...and let the wax run down into the stud threads. It works...trust me. With excessive heat on the cases, you risk warping. Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted July 8, 2009 Report Share Posted July 8, 2009 Heat the stud up, press a candle to it, any kind...and let the wax run down into the stud threads. It works...trust me. With excessive heat on the cases, you risk warping. Yep. Bees wax works wonders ! Quote Link to comment Share on other sites More sharing options...
Thewhite Posted July 9, 2009 Author Report Share Posted July 9, 2009 thanks guys, I will try the wax in the week-end. When I heated the stud last weekend, I begun slowly with the heat and the stud was rock solid in the case. So I heat it again and at the third time the stud bent just a little bit. My last tried was to heat the stud and colling it with ice in a towel by the othe end. That havent work too. thanks Quote Link to comment Share on other sites More sharing options...
banshee(911) Posted July 9, 2009 Report Share Posted July 9, 2009 thanks guys, I will try the wax in the week-end. When I heated the stud last weekend, I begun slowly with the heat and the stud was rock solid in the case. So I heat it again and at the third time the stud bent just a little bit. My last tried was to heat the stud and colling it with ice in a towel by the othe end. That havent work too. thanks ive always took mine to a machine shop Quote Link to comment Share on other sites More sharing options...
Darthwall Posted July 9, 2009 Report Share Posted July 9, 2009 try the wax trick I was skeptical about it so I only did a few studs the ones I put wax on came out the ones I didnt broke off inside the case I also put a torch to all of them the ones with wax where easier the ones without I maybe got a turn out of them then snapped off Quote Link to comment Share on other sites More sharing options...
Thewhite Posted July 26, 2009 Author Report Share Posted July 26, 2009 (edited) Thanks guys for the candle or wax trick. The stud go out so easily and even the local shop was not sure if they will be able to do it without breaking the stud ... always good stuff here ... Anyway, I have already sent my space case to Jeff for a full case porting. Edited July 26, 2009 by Thewhite Quote Link to comment Share on other sites More sharing options...
