Chariot Performance Posted July 6, 2009 Author Report Posted July 6, 2009 Same place as you. QuickSand Thanks for the pictures. The 250r caliper looks a lot like the earlier yfz450 calipers. We are making a lot of progress on the caliper design. I expect we will have some done in about 6 weeks. Thanks again for all the info and suggestions. Quote
FireHead Posted July 6, 2009 Report Posted July 6, 2009 I have the same exact setup as Flash & Flare has. Wanna see some pictures :cool: Follower....... :biggrin: Quote
FireHead Posted July 6, 2009 Report Posted July 6, 2009 I know for the drag guys they remove front brakes. How many people would be interested in dual piston front brakes as well? Desert guys? Asphalt guys? The YFZ450 front setup will probably cover most folks needs on the front.... I didn't run front brakes on my hill/drag bike and the OEM Banshee caliper wasn't enough to slow it down....... A bigger rear caliper that is a direct bolt-on is probably what most folks need. You need to probably use some type of OEM pads from a sport bike to make the product useful. Some of the Formula Atlantic cars run pad from a litre bike on their diff. outputs in an integrated opposed 3 piston caliper design (6 pistons total). I could see making a single caliper setup like that work pretty well, but plunge EDM'ing or gun drilling the fluid ports is a design drawback for such a long style of caliper. :geek: Quote
Chariot Performance Posted July 6, 2009 Author Report Posted July 6, 2009 The YFZ450 front setup will probably cover most folks needs on the front.... I didn't run front brakes on my hill/drag bike and the OEM Banshee caliper wasn't enough to slow it down....... A bigger rear caliper that is a direct bolt-on is probably what most folks need. You need to probably use some type of OEM pads from a sport bike to make the product useful. Some of the Formula Atlantic cars run pad from a litre bike on their diff. outputs in an integrated opposed 3 piston caliper design (6 pistons total). I could see making a single caliper setup like that work pretty well, but plunge EDM'ing or gun drilling the fluid ports is a design drawback for such a long style of caliper. :geek: As of now I plan on making some two piston and four piston all opposing rear calipers. My guess is that the dual piston will work just slightly better than a dual piston yfz450 caliper and the four piston will satisfy all other requirements. Just a guess so far but we'll see. Thanks Quote
dajogejr Posted July 6, 2009 Report Posted July 6, 2009 Let me know when I can stop by to pick mine up... Quote
Bansh-eman Posted July 6, 2009 Report Posted July 6, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? Quote
FireHead Posted July 7, 2009 Report Posted July 7, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? That is a good question. It all depends on the size of the piston used. It is definitely a design challenge. :geek: Quote
Chariot Performance Posted July 7, 2009 Author Report Posted July 7, 2009 Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? I believe they will work fine. We will see! Quote
sprinklerman Posted August 25, 2014 Report Posted August 25, 2014 QUOTE (Bansh-eman @ Jul 6 2009, 07:24 PM) Is the Banshee master and reservior capable of producing the power and fuild capacity needed to support such an application? I believe they will work fine. We will see! what was the final outcome of this project ? Quote
trickedcarbine Posted August 26, 2014 Report Posted August 26, 2014 On the shelf next to the carbs? It would be sweet but not practical I bet. Although, some drag guys would love an ultra light with rear. Or some type of zero drag that doesn't fall off. Quote
trickedcarbine Posted November 29, 2017 Report Posted November 29, 2017 Could a Billit dual piston caliper be lighter then the 250r or new 450stuff or even the popular Brembo? Quote
TrickedCarbine01 Posted November 29, 2017 Report Posted November 29, 2017 Something like this would be tits, but those Beringer brakes are probably 2-3K. Sent from my iPhone using Tapatalk Quote
Chariot Performance Posted December 5, 2017 Author Report Posted December 5, 2017 Yes they are on the shelf next to the carbs. We have been swamped the last 3 years and the carb is a big big project. We may pick up both these projects in the next year. Jerry Quote
