look at the chain. Inbetween the inner and outler link plates there will be o rings in there. They seal help seal dirt out so it doenst wear the pins out as fast.
A stocker will be an o-ring. Most Banshees chains are o-ring even if you dont specifiy at a cycle shop they usually just give you an o-ring chain. Like the above poster said, just look between the links.
