doorslammer Posted June 14, 2009 Report Posted June 14, 2009 hey all im just putting 28mm PWK's on my bike and run a cr twist throttle, what cable sould i use (if theres one avalible) and where can i get it? thanks Quote
LiftdT4R Posted June 14, 2009 Report Posted June 14, 2009 I would probably use the cable for the 29PWKs with a stock throttle. When I ran the 28PWKs I ordered a cable for the PWKs and a stock throttle except I had a Terry Cable Dual Gasser and it worked fine. If yo call up CPW, Carb Parts Warehouse they should have the cable, and if you tell them its for a twist they might be able to make a better suggestion on the cable. Good luck!! Quote
