stokes77 Posted June 13, 2009 Report Posted June 13, 2009 Anyone? I've looked and looked and I got no clue where the o-ring is supposed to go that I got with these carb kits. Quote
gst_r Posted June 13, 2009 Report Posted June 13, 2009 if i remember right the o ring goes on the choke...it is the choke o-ring.. Quote
stokes77 Posted June 13, 2009 Author Report Posted June 13, 2009 if i remember right the o ring goes on the choke...it is the choke o-ring.. I don't know where on the choke it would go... The O-ring I am talking about is like an inch in diamater Quote
sleeper06 Posted June 14, 2009 Report Posted June 14, 2009 There is an o-ring on rthe brass seat,remove the phillips screw and pull up Quote
swrbansheeboy Posted June 14, 2009 Report Posted June 14, 2009 agreed, probably the o-ring on the brass seat for the float needle... Quote
AKheathen Posted June 14, 2009 Report Posted June 14, 2009 umm...the one for the seat is a little smaller than the choke, and definately not 1" there is a flat seal about that size, for the cap Quote
itsaripper Posted June 14, 2009 Report Posted June 14, 2009 A lot of rebuild carb kits are made up for more than one motor applacation. The O-ring you have is prolly to a motor that has the same Mikuni 26 carb but it bolts on instead of having a snout that goes into a rubber mount. The O-ring goes around the inlet on the intake. Honda four strokes use that style of carb. If you didn't find one in the carb taking it apart it isn't for your applacation. Quote
