Just got my clutch kit from Jeff an a pancake bearing adjuster. Not even sure where it goes but I'm sure it will b noticinle when I get clutch cover off? Also how do I adjust it?
It goes in the center of your pressure plate. You got to remove all the screws and springs from the pressure plate, then pull the old adjuster out. Put the new one in with the bearing against the adjuster and pressure plate, you may have washers that goes on the utside of the bearing depending on what kind you got. Either way its the same thing, put it back in the pressure plate and use the nut to lock the set screw in place once you have everything bolted back up and adjusted.
The one I got from Jeff is from cascade, It does have washers. Thanks for the reply, i was bginning to think nobody installed thier own. :ermm:
