TeamRealtreeHD Posted May 29, 2009 Report Posted May 29, 2009 Was running a set of HJR ported stockers last year, with all the goodies to go along with it... gearing was 14/41 (or whatever stock is) and it was very nice... Now it gets tricky. Got a 421 Cub, Kevin ported it, cleaned up the ports, raised them a little, did some mad scientist work for my build so to speak. Anyways, will be running that along with a duneable 1-5 overide. So in order to get the gearing somewhat close to where I liked it before, in terms of how wide the gears were... Where do I start? 16/41, 16/40, etc. I am leaning towards a 16 tooth in the front... but not sure if I should change the rear. All advice is appreciated... the main concern here is to get the gear WIDTH as close to possible to what I was running with the 1-6 stock tranny... Quote
BellicoseBanshee Posted May 29, 2009 Report Posted May 29, 2009 So, are you wanting to gear it so that 1st on the override is similar to 2nd on a stock transmission? Quote
TeamRealtreeHD Posted May 29, 2009 Author Report Posted May 29, 2009 So, are you wanting to gear it so that 1st on the override is similar to 2nd on a stock transmission? I would have to say, in a nutshell, that is what I mean... more so along the lines of maybe getting 2nd gear to be what my 3rd was before, or the old 2nd gear screaming.... Gotta make the 2nd gear a good one hear... I need it to climb hills in 2nd gear... I don't think 1st is what I want lol Need the power, but can't widen it too much so it won't bog, if you guys know what I mean. Basically, need 2nd gear to pull and never stop pulling, and be a good width if you know what I mean. I think the cub will be able to pull the 16 tooth rather easily. Most likely will start there, and maybe play with the rear as time goes on... Quote
TeamRealtreeHD Posted May 29, 2009 Author Report Posted May 29, 2009 Kevin is recommending a 17 front, and 39-42 rear. So that is definately where I will start, the 17 atleast. Any advice on the rear??? Quote
dajogejr Posted May 29, 2009 Report Posted May 29, 2009 17 might be a stretch depending on your weight and tire size/type. I run 16/44 or 16/45 but that's to launch in second in 300 feet, my 10 mil also has a little more lungs than a 4. I would try 16/41 and start there. If it just blows through 1st gear, go up to a 17/42... You got a cub now, it'll run...but it won't have quite the same bottom end as a stocker done right, IMO. Dunable override was a smart choice, that'll help keep it on the pipe. Quote
okbeast Posted May 29, 2009 Report Posted May 29, 2009 Damn you guys run low gearing. I'm running 13/42 and love it on my 421 cub. I guess I'll have to try a 14 this summer and see how it does. Everything I've been reading lately has pointed me to gearing it a little lower, but I like the snap that the 13 gives me. Quote
blanco25 Posted May 29, 2009 Report Posted May 29, 2009 iv kinda got the same setup. ive ran 17-39 not my cup of tea. now i run 15/40. which is good for where i ride. went to little sahara last weekend and i needed different gearing. so when i go there since the hills are way steeper than dumont im going to need 15/42or43 probably. best thing to do is try them all and see what works for you and when you find it sell the ones you will not use anymore. i mean this could get figured out in 1 dya of riding. Quote
dajogejr Posted May 29, 2009 Report Posted May 29, 2009 Good post. I wouldn't sell the other sprockets though, you'll get pennies on the dollar for what you paid for them, plus, one area might need gearing that another doesn't. Not to mention...you smack a rock, it breaks/bends your sprocket, a spare can save the day. Quote
BellicoseBanshee Posted May 29, 2009 Report Posted May 29, 2009 I'm running 13/42 and love it on my 421 cub.I think you are the first person I have ever heard that likes a 13 with a cub. That is interesting... With an override, I really like the 15-40/41/42 range... Quote
okbeast Posted May 29, 2009 Report Posted May 29, 2009 Well I had it on there with my stocker ported cylinders and loved it, it launches in 2nd great, 3rd hits really hard, rarely get out of 5th gear. That's why I was wondering why so many people run such big front sprockets. I'm gonna try stock gearing when I get a new chain and see how I like it. I'm hopin it'll keep the front end from comin up some and spread the gears out a little bit. Quote
TeamRealtreeHD Posted May 29, 2009 Author Report Posted May 29, 2009 What is a stock rear, 41? I believe I will try 16/41 to start... see what that gets me. Should be in the general ballpark of where I need it to be... with the 1-5 Quote
vulvafan537240 Posted May 30, 2009 Report Posted May 30, 2009 What is a stock rear, 41? I believe I will try 16/41 to start... see what that gets me. Should be in the general ballpark of where I need it to be... with the 1-5 yeah. stock is 14/41. Quote
