Mike DUB Posted May 28, 2009 Report Posted May 28, 2009 I think its a few rubber bushings in the top and bottom of both front shocks that need to be replaced but not sure. I looked at the parts I needed here at this website but it doesnt specify that the same part number for the top of the shocks works for the bottom of the shocks (http://www.cyclepartswarehouse.com/fiche_section_detail.asp?section=20728&category=ATVs&make=Yamaha&year=1993&fveh=529). Can someone help? do you know for sure that if I buy four of the (#34 DAMPER, BUSH B 59V-2331R-00-00) parts listed for the tops of the shocks will they also work for the bottom of the shocks? (2 for left side and 2 for right side, top and bottom) I have pictures but I can't get them to post. Darn NEWBIES! Thanks hope I made sense. Mike Quote
MikeNick Posted May 29, 2009 Report Posted May 29, 2009 Those on that part fiche only show bushings for the top, Rockymountainatv has some for top and bottom but they are more expenisve. http://www.rockymountainatv.com/productDet...odFamilyId=9236 Quote
Mike DUB Posted May 29, 2009 Author Report Posted May 29, 2009 Those on that part fiche only show bushings for the top, Rockymountainatv has some for top and bottom but they are more expenisve. http://www.rockymountainatv.com/productDet...odFamilyId=9236 do u think that's what i need from what i said? hope this helps! thank God for lil borthers. man four years ago i was teaching him. Quote
MikeNick Posted June 1, 2009 Report Posted June 1, 2009 If the shocks are loose on the lower and upper mounts and the bolts are tight then yes, the bushings are fucked. Quote
Mike DUB Posted June 2, 2009 Author Report Posted June 2, 2009 If the shocks are loose on the lower and upper mounts and the bolts are tight then yes, the bushings are fucked. Thanks Bro. i appreciate the help Quote
KlotzBanshee Posted June 3, 2009 Report Posted June 3, 2009 I have a set of banshee stock front shocks off of my 99 in very good shape if you are interested. I put YFZ450 shocks on so the other ones are just sitting around. Quote
MikeNick Posted June 3, 2009 Report Posted June 3, 2009 Thanks Bro. i appreciate the help No problem man.. :smile: Quote
