800screws Posted May 16, 2009 Report Posted May 16, 2009 (edited) here's what i got, engine is entirely brand new with all new crank inserts, new bearings, new crank, all new forks, drums, etc...backcut gears. the whole quad has just been built, only ran to jet it. EMAIL ME ALSO FOR MORE PICS...IT WILL ONLY LET ME POST ONE???? LOOKING FOR A MX BANSHEE-PREFER A LONG TRAVEL WITH AFTERMARKET SUSPENSION, 2 INTO 1 CARB, AFTERMARKET SWINGARM. I WILL CONSIDER NON LONG TRAVEL BANSHEES WITH CASH TO THE DEAL. NO BEAT, RIGGED, OR BASKET CASES....USE YOUR HEAD WHEN SENDING OFFERS.... U CAN EMAIL ME AT [email protected] WITH PICS AND INFO IM LOCATED IN PORT JERVIS, NY 12771 JP OUTLAW LT250/500 outlaw frame uses 250r geometry with lt250r plastics and componets. trx250r laegers t pin front end-recently rebuilt, no play in the bearings, freshly greased trx250r front brakes trx250r duncan racing billet front hubs trx250r 4 1 offset douglas front rims with mx holeshots 20" lt250r +1 burgard stem brand new and lsr anti vibe 7/8 clamp and gibson oversize clamps asv bendable levers brand new new flex bars with oury grips new motion pro vortex twist throttle and new cable and oem suzuki thumb throttle new clutch cable and throttle cable trx250r ac front bumper braided front/rear brakelines 92 oem seat new maier race plastics with 91 oem graphics newgraves motorsports seatcover-also have another graves cover to go with it. oem plastics jp lt250r round housing swingarm with trx250r rear linkage including a durablue adj. strut tm designworks chain slider and new rear chain slider rad black locknuts lsr brake and rotor hub lsr +4 axle durablue lt250r with 4/110 pattern rear hubs new10" douglas beadlocks with 19" holeshot mxr4 ac racing nerfbars hre new subframe jp aluminum airbox with trx250r k&n filter and uni filter new sb designs billet engine mounts pro design killswitch new dr.q hybrid pipe and silencer extra dg pipe and curtis sparks silencer new 89 lt500r engine with full dr.q 540 hrd top end new dr.q no blow rcm head, base, and intake gaskets new v force 2 reed cage dr.q 42.5 rx'd mikuni carb with k&t oversize float bowl-starts on first kick dr.q lightned flywheel dr.q rx'd piston with rm250 bearing and billet thrust washers-less than 1 hour run time pingel fuel valve new rpm grab bar in line cooler custom axis shocks pep easy pull clutch arm new ricky stator stator amr monster coil jp steering stem clamp powermad handguards 450r master cylinder and asv rotator clamp billet shock rezzie clamps lsr axle carrier billet brake stay aluminum airbox in line rad cooler new dark blue maier screened numberplate hoodscope and cap frame rewelded and reworked for dr.q pipe, gusseted by romar race shop $1300 have reciept new powdercoat on frame and subframe new bearings brand new engine done by rxhp-new bore and piston, engine hardware, new paint. oil seal set gear 4th drive " " " driven " " 5th driven guide gear shift bolt 6x16 [1] screw [2] bolt 6x40 [4] bolt 6x55 [5] bolt 6x65 [6] bolt 6x25 [1] fork fork fork stopper shifter screw [4] shift drum lifter shifter bushing ex o-ring o-ring o-ring dowel pi cyl o-ring water pump shaft washer drain plug gasket clutch gasket mag piston hot rod kit shaft shift fork clutch springs -------------------------- case inserts bore cly take motor apart and inspect put motor back together ,do leakdown test,paint install new rod backcut gears Edited May 16, 2009 by 800screws Quote
Mjv420 Posted May 17, 2009 Report Posted May 17, 2009 another... Man those fuckers are ugly, whoever was designing back then for suzuki should be shot. Definetely looks as its been taken care of though. Quote
87sheerips Posted May 17, 2009 Report Posted May 17, 2009 Yea, it may be ugly but its BADASS!! Good luck on the trade, I actually have a banshee that would be a good trade but NO WAY could I let it go.. Bump for a sweet quad man. Quote
800screws Posted May 18, 2009 Author Report Posted May 18, 2009 anyone? got the old plastics and seat on it....going to start riding it.... Quote
jacob08 Posted June 17, 2009 Report Posted June 17, 2009 If your still looking for a banshee i have a 2001 with many mods denton +1+1 A arms Cpi Pies after market suspension in front and many other mods that i can send later becasue i am on the wrong computer to put it all but there is around 7000 in aftermarket parts. if your interested email me at [email protected]. Quote
high octane junkie Posted June 18, 2009 Report Posted June 18, 2009 very nice. i had a Q 535 that i got from butters but then re-sold before i ever got to run it, as close to the hrd540 as you can get without actually having a hrd540. makes me miss my zilla. Quote
MikeNick Posted June 18, 2009 Report Posted June 18, 2009 Man those fuckers are ugly, whoever was designing back then for suzuki should be shot. Definetely looks as its been taken care of though. Shit, that looks a hell of alot better than a stock one..Stock they're ugly as fuck but that one there is sweet! Quote
