here's what i got, engine is entirely brand new with all new crank inserts, new bearings, new crank, all new forks, drums, etc...backcut gears. the whole quad has just been built, only ran to jet it.
EMAIL ME ALSO FOR MORE PICS...IT WILL ONLY LET ME POST ONE????
LOOKING FOR A MX BANSHEE-PREFER A LONG TRAVEL WITH AFTERMARKET SUSPENSION, 2 INTO 1 CARB, AFTERMARKET SWINGARM. I WILL CONSIDER NON LONG TRAVEL BANSHEES WITH CASH TO THE DEAL. NO BEAT, RIGGED, OR BASKET CASES....USE YOUR HEAD WHEN SENDING OFFERS....
U CAN EMAIL ME AT [email protected] WITH PICS AND INFO
IM LOCATED IN PORT JERVIS, NY 12771
JP OUTLAW LT250/500
outlaw frame uses 250r geometry with lt250r plastics and componets.
trx250r laegers t pin front end-recently rebuilt, no play in the bearings, freshly greased
trx250r front brakes
trx250r duncan racing billet front hubs
trx250r 4 1 offset douglas front rims with mx holeshots 20"
lt250r +1 burgard stem brand new and lsr anti vibe 7/8 clamp and gibson oversize clamps
asv bendable levers brand new
new flex bars with oury grips
new motion pro vortex twist throttle and new cable and oem suzuki thumb throttle
new clutch cable and throttle cable
trx250r ac front bumper
braided front/rear brakelines
92 oem seat
new maier race plastics with 91 oem graphics
newgraves motorsports seatcover-also have another graves cover to go with it.
oem plastics
jp lt250r round housing swingarm with trx250r rear linkage including a durablue adj. strut
tm designworks chain slider and new rear chain slider
rad black locknuts
lsr brake and rotor hub
lsr +4 axle
durablue lt250r with 4/110 pattern rear hubs
new10" douglas beadlocks with 19" holeshot mxr4
ac racing nerfbars
hre new subframe
jp aluminum airbox with trx250r k&n filter and uni filter
new sb designs billet engine mounts
pro design killswitch
new dr.q hybrid pipe and silencer
extra dg pipe and curtis sparks silencer
new 89 lt500r engine with full dr.q 540 hrd top end
new dr.q no blow rcm head, base, and intake gaskets
new v force 2 reed cage
dr.q 42.5 rx'd mikuni carb with k&t oversize float bowl-starts on first kick
dr.q lightned flywheel
dr.q rx'd piston with rm250 bearing and billet thrust washers-less than 1 hour run time
pingel fuel valve
new rpm grab bar
in line cooler
custom axis shocks
pep easy pull clutch arm
new ricky stator stator
amr monster coil
jp steering stem clamp
powermad handguards
450r master cylinder and asv rotator clamp
billet shock rezzie clamps
lsr axle carrier
billet brake stay
aluminum airbox
in line rad cooler
new dark blue maier screened numberplate hoodscope and cap
frame rewelded and reworked for dr.q pipe, gusseted by romar race shop $1300 have reciept
new powdercoat on frame and subframe
new bearings
brand new engine done by rxhp-new bore and piston, engine hardware, new paint.
oil seal set
gear 4th drive
" " " driven
" " 5th driven
guide gear shift
bolt 6x16 [1]
screw [2]
bolt 6x40 [4]
bolt 6x55 [5]
bolt 6x65 [6]
bolt 6x25 [1]
fork
fork
fork
stopper shifter
screw [4]
shift drum
lifter shifter
bushing ex
o-ring
o-ring
o-ring
dowel pi cyl
o-ring
water pump shaft
washer drain plug
gasket clutch
gasket mag
piston
hot rod kit
shaft shift fork
clutch springs
case inserts
bore cly
take motor apart and inspect
put motor back together ,do leakdown test,paint
install new rod
backcut gears
Edited by 800screws
another...
Man those fuckers are ugly, whoever was designing back then for suzuki should be shot.
Definetely looks as its been taken care of though.
Yea, it may be ugly but its BADASS!! Good luck on the trade, I actually have a banshee that would be a good trade but NO WAY could I let it go.. Bump for a sweet quad man.
  • 5 weeks later...
If your still looking for a banshee i have a 2001 with many mods denton +1+1 A arms Cpi Pies after market suspension in front and many other mods that i can send later becasue i am on the wrong computer to put it all but there is around 7000 in aftermarket parts. if your interested email me at [email protected].
Shit, that looks a hell of alot better than a stock one..Stock they're ugly as fuck but that one there is sweet!
