jse28 Posted May 16, 2009 Report Share Posted May 16, 2009 I'm buying a coolhead and am wondering what domes to get mods include K&n filter no lid, dmc 916, 28mm pwk, boss intake, and I run 91oct with motorwerx at 40:1. My elevation is around 1500 feet. Thanks fellers Quote Link to comment Share on other sites More sharing options...
Darthwall Posted May 16, 2009 Report Share Posted May 16, 2009 I think the lowest domes you want to go with to still run pump gas are 20cc but ya 21-20 should be good for that Quote Link to comment Share on other sites More sharing options...
shee4speed Posted May 16, 2009 Report Share Posted May 16, 2009 you running any timing? Quote Link to comment Share on other sites More sharing options...
jse28 Posted May 16, 2009 Author Report Share Posted May 16, 2009 you running any timing? I was just thinking about that you think i should. Quote Link to comment Share on other sites More sharing options...
Loc Posted May 17, 2009 Report Share Posted May 17, 2009 I would go with a 21cc to keep it safe. Quote Link to comment Share on other sites More sharing options...
jse28 Posted May 17, 2009 Author Report Share Posted May 17, 2009 I was just thinking about that you think i should. do i need to put longer studs in the jugs for a cool head? I dont have it yet just want to have everything i need when i get it. Thanks fellers Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted May 17, 2009 Report Share Posted May 17, 2009 Yes, a Pro Design head requires longer studs. PD sells a stud kit for it... Quote Link to comment Share on other sites More sharing options...
Darthwall Posted May 17, 2009 Report Share Posted May 17, 2009 if you go with a noss head or modquad or I think chariot performance then you can use your stock studs and all the domes are interchangable from each head Quote Link to comment Share on other sites More sharing options...
shee4speed Posted May 18, 2009 Report Share Posted May 18, 2009 if you go with a noss head or modquad or I think chariot performance then you can use your stock studs and all the domes are interchangable from each head + at Noss you get a 10% discount for being on the HQ. Quote Link to comment Share on other sites More sharing options...
