I just took delivery of my RAZR tires from RMATV. I had them mounted and the tire guys and I noticed that w/ the equal amounts of air the tires were shaped different. One was bowed out like it was over inflated the other was flat like normal. Also the bubbled out one measured 1.2 inches taller. Anyone ever have this happen? They remounted them several times, but no fix. They are on there way back to RMATV already. Replacements are backordered til July. This sucks...
did you check to see if they are the same size and ply rating? Guess it doesnt matter though cause that is obviously not right. Back ordered till July? Thats shitty. I would ask for a refund unless you can make due till then. Their back order shit changes alot back and forth on alot of things.
The tires' markings matched exactly. RM is sending a refund but would either pay for restocking or my mounting dis-mounting charges, not both. I am going to try to find some tires locally, while it is not 110F outside yet.
