well i bought a brand new lockout for my boys banshee.. first i put a baranett clutch with the heavy duty springs in... so when we ride it it won't shift tell you let it come almost back to a idle.. so then i put the softer springs in.. alittle better, but still really sucks.. i am wondering if it is from the baranett clutch plates ? are they alittle thiner making the arms on the lockout to close to much and not want to unlock when you pull the clutch ? it is on a 4 mill.... i put one on me yfz and it works with out any problems.. thanks for any help
Edited by millertime
Some people have luck with a lockout and being able to shit without an override, some don't.
What kind of motor do you have that you need a lockout and not just a quality clutch and some HD springs?
Most of the time, in the Banshee World, a lockout is coupled with an override tranny, no clutch needed to shift.
Is the basket, inner hub and pressure plate in good working order, and do you have enough slack in the clutch cable?
Is the shifter adjusted properly?
Another question: Who made the lockout? (I'm asking since they are not all made the same, and I am aware of atleast a couple that seem to be really low quality). :geek:
it is a 4 mil, 18cc domes, 34mm carbs,,, cpi pipes... my boy is a big boy , and we race up dunes at st. anthony dunes.. he is hard on clutches.... clutch and plates barnd new,,, new inner clutch boss.. clutch basket looks good.. no groveing... oh it is a direct drive lockout and cover
ya the shifter centering pin is adjusted... tryed more slack in the cable and less.. no differance
Man i'm in the same boat! Got a lockout on mine maybe have 4 or 5 hours on the motor and now it wont shift. Soon as i get the money saved up its goin back to M&M for a overide. I was warned before i opted not to do the o/r that this was prolly gonna happen. Wish i would have listened
With that kind of weight, power and load on the motor...I think you might be facing the nature of the beast.
Dunable override in your future?
Can someone enlighten me here: I have run Direct Drive's setup on several bikes that I have owned that made way more power than the bike in question here and I never had a problem like this. Is there some other variable that we are missing here? I am not sure the dunable override is the solution to you problem, it's just a bandage. :geek:
In my experience, even with brand new innards and everything properly adjusted, once you get in the 80 to 90 HP range...they shift like crap.
With our without a lockup.
Now, is that the case with all bikes? No.
Lighter riders? No.
Trail riders not hooking up as much as a slick tired street bike or paddled tired dune bike? No.
With the motor revving to the moon and the clutch not disengaging all the way (hence the motor coming back to near idle) it's only gonna make it shift even worse.
I'm a big guy, and I ride in sand. Sounds like this guys is in a similar boat.
As long as his tranny components are in good shape (it sounds like his clutch is new and/or in good working order) it's my opinion he's at the limit of what a stock tranny can do with this setup in his enviornment.
I've tried shift pro kits, rounded shift stars, trannys with every other dog cut...they all help it shift "better" but not like it should.
And...
I have pretty good pricing on overrides...:)
o no, i just bought one....from direct drive. i hope this dosnt happen, im only getting this because i do plan on reaching the 90hp area sometime next season but for this season i need to build my quad up to be ready for the punishment.
I had an 80 to 85 horse gas dunner and had the same problems shifting w/just stiff springs. I tried everything as well. Went w/the override, shifted like butter but started burning up clutches. Finally got a lockup and never had another problem. My buddies bike is in the 70 horse range and he has never had a problem shifting it. I get on it, and works good for me as well...I have no idea why???
Lighter riders? No.
And...
I am not a small guy and I think that I ride or used to race in similar circumstances. I use a shift pro kit and a modified star with mostly aftermarket drive/clutch components.............. I just don't have the same type of problems. In any case, if you make sure you break torque to shift like you do with any type of transmission, then I still believe there is something else wrong here. :geek:
