liveordie72089 Posted April 27, 2009 Report Posted April 27, 2009 Hey I got a problem I just rebuilt my banshee and now when I go to hit the clutch it works for a little bit but then just something happens and It can pull very easy. I don't know whats wrong with it then I take off the cover tighten the bolt and it does it again. Any ideas. Bought a new push lever assembly Quote
lt250rfd Posted April 27, 2009 Report Posted April 27, 2009 Hey I got a problem I just rebuilt my banshee and now when I go to hit the clutch it works for a little bit but then just something happens and It can pull very easy. I don't know whats wrong with it then I take off the cover tighten the bolt and it does it again. Any ideas. Bought a new push lever assembly had the same thing happen to my 96. the jam nut was striped out on mine, it would work for a few minutes then the nut would back it self off and lose the clutch tension. i put a new one on and rode it for a few minutes today seemed ok so far. Quote
SD1026 Posted April 27, 2009 Report Posted April 27, 2009 when the bolt comes loose does it cause a nocking noise i am having a similar problem Quote
liveordie72089 Posted April 27, 2009 Author Report Posted April 27, 2009 when the bolt comes loose does it cause a nocking noise i am having a similar problem No knocking noise at all. It just comes loose and goes to no clutch. Ima try and go to lowes to get a new bolt. Quote
liveordie72089 Posted April 27, 2009 Author Report Posted April 27, 2009 had the same thing happen to my 96. the jam nut was striped out on mine, it would work for a few minutes then the nut would back it self off and lose the clutch tension. i put a new one on and rode it for a few minutes today seemed ok so far. Let me know if it fixes the problem. Quote
lt250rfd Posted April 27, 2009 Report Posted April 27, 2009 Let me know if it fixes the problem. you are talking about the center clutch adjustment nut on the pressure plate? Quote
liveordie72089 Posted April 27, 2009 Author Report Posted April 27, 2009 you are talking about the center clutch adjustment nut on the pressure plate? Yeah I am talking about that one. Is that the part that you are talking about you replaced? Quote
lt250rfd Posted April 28, 2009 Report Posted April 28, 2009 Yeah I am talking about that one. Is that the part that you are talking about you replaced? yes, i actually got a used 06 pressure plate with the nut, washer, and rod off of ebay. i only rode a few minutes up and down my street and it seems to be alright so far. before i replaced it i kept jacking with the old one i could only get to the end of my street and it back it self off and lose the clutch. did that three to many times, plus the loss of oil and coolant. if it dries out enough this week i'm hoping to take it for a spin. Quote
liveordie72089 Posted May 4, 2009 Author Report Posted May 4, 2009 Anyone else know what the problem can be? Its kinda making me wanna get rid of my banshee now. Quote
