shee23 Posted April 23, 2009 Report Posted April 23, 2009 i just recieved some used cylinders that i bought and the guy told me they were stock 64mm bore but they dont look like it. it looks like the sleeve and ports have been smoothed out. is there any way to tell without a micrometer? Quote
trex banshee Posted April 24, 2009 Report Posted April 24, 2009 did they happen to come with pistons? Quote
nuc_welder Posted April 24, 2009 Report Posted April 24, 2009 Heres a conversion chart to convert from inches to mm http://www.worldwidemetric.com/metcal.htm Quote
Ducman Posted April 24, 2009 Report Posted April 24, 2009 You need at least a set of dial callipers to measure the bore size accurately enough. You can pick one up at a tool shop for around $20. Or just go to a mechine shop and have them measure it. If you have pistons that fit the cylinders then the bore size is stamped on the dome of the piston. Quote
