nuc_welder
Everything posted by nuc_welder
  1. I know its not a banshee, but not sure where to look. If anyone knows a site that is as helpful as this one for a yfz please let me know. K well rebuilding the top end just wanting to know if there is anything special to it, like timing or anything? Everything else seems to pretty self explainatory.
  2. Heres a conversion chart to convert from inches to mm http://www.worldwidemetric.com/metcal.htm
  3. I bought a boss intake, the boots are for a 34-36mm carb, I've got 30mm carbs now, anyone know if the vitos boots will fit and if not where can I pick up a set of boots at?
  4. Never thought bout that, prolly wouldn't hurt to check its an 02 and its never been checked.
  5. K thanks to all that replied, Finally found one today at the local hardware store, I was thinkin that it was metric, turns out its SAE, 7/8 14. Guess I should of tried both!
  6. Are you sure I thought that the g-force was a little bigger?
  7. Luck keeps gettin bad, stripped out the axle nut on my g-force axle, now I cant find one anywhere, checked parts stores, ebay, rocky mountain and still no luck. Anyone ever had to replace them, or know where to find one? It's not the lock nut, its the nut that holds the rear hub on. Need help bad ::
  8. Anyone know bout what needles need to be?
  9. What about the needle?
  10. yah its a banshee
  11. What kind of shape is the skid plate in? Can you post a pic of the under side?
  12. Ok my friends bike has a noise that kinda sounds like a collapsed lifter in a car, it has tapped for a while but not real noticable, till he had a head gasket blow out this winter, he had it replaced and now its loud. Any Idea bout what it might be? The bike still has alot of power just sounds bad.
  13. My friend has a set of 35 keihin's and needs to know where to be at on his jets. His mods are 4mill stroker with long rod, cpi inframes, vf 3 reeds, k&n pods, clean up port, stock bore. We ride in southern missouri, mainly draggin on the highway, bout 700 feet above sea level, 60 to 75 degrees, he ways bout 165. If you need more info I get it.
  14. Well I've been looking at pistons on ebay and I seen some M&H pistons on there half the price of wiseco. Anyone run these before or know if they're any good?
  15. Ok well I mic'd my cylinders today, they measured 2.545" which converts to 64.643mm, so I would need to buy a set of 64.50 pistons right, if not what size do I need?
  16. I've got a set of 30mm mikuni carbs, my right idle screw is missing, will the vito's screws fit my carbs? I didnt see a size chart on the link.
  17. So it should mic. out at 2.519 in(for a 64mm bore)?
  18. O.k well been looking around with no luck, I just bought a set of cylinders the guy said they're stock bore. Just want to know what the conversion ratio is from mm to in. (or what a stock bore is in inches) I dont have any way to measure metric stuff.
  19. I know I should do it, but if I'm gonna got through the trouble to take the crank out, I might as well put a stroker in. Just don't have the funds to do all at the same time, with riding weather approaching I'd like to get it ready as soon as I can. Hopefully by next winter I'll be able to put that stroker in it. I'm not really looking for a blessing, but some reasurance that it's not gonna blow sky, high would be nice.
  20. O.k I searched around but had no luck in finding an answer. I'm putting drag ported cylinders, with boost ports, at stock bore, on my bike. Is it nesessary to have my stock crank welded, or will it handle my little mods? I mainly drag on the highway, with a little flat trackin. Planned mods, drag ported cyl. (with boost ports) cool head w 19 cc domes vf3 reeds + 6 timing ( im using 114 race gas) Also are my carbs gonna be big enough or should I just get a set of 35mm pwks?
  21. If deal falls through I'll take em.
  22. Just want to know if I can use a set of alky carbs for gas? I know I'll have to do a little work on them first. Just seems like theres more alky carbs for sale than gas carbs.
  23. Tried to send you a pm, but your inbox is full.
  24. Are they still for sale? If so I'll take em.
  25. I've got a set of 30mm mukuni's with couple spare jets, if your interested I can send you some pics.
