shee23
Everything posted by shee23
  1. Domes are brand new never installed. Cut by Kevin at HJR $75 shipped
  2. Pro design cool head ( new) $150 Cylinders .20 over 4 mil dune ported w/ pistons ( only brake in period less than 1 hr) $650 4 mil cut domes 18mm and 22mm $50 each 4 mil weisco crank +5 rods ( less than 1 hr) $250 Trans with cases, Hinson clutch basket with heavy duty clutch $350 CPI in-frame exhaust $400 V-force 3 reeds $100 33 pwk kein carbs $220 33-35mm k&n air filters $60 Pwk over sized radiator $125 Full flight +2+1 a arms $225 Yfz 450 front shocks off of 07 $125 +2 rear billet hubs $60 Red plastics with graphics and seat ( minor crack on right side of seat) $300 Tag freestyle bars $50 From Reno, NV local pick ups are welcome. Shipping will vary on all items. I will have pictures up this evening. PM me for more details if interested
  3. just carbs for sale
  4. need cash man sorry
  5. Selling my air strikers going back down to stock for a smaller motor. These things are in great shape and only have a few hrs of ride time on em. I will post pics tonight but pm me if your interested and I can email the pics strait to you. thanks $325.00 shipped both are in excellent condition!
  6. i think im just going to have to buy a shorter stud because the stock wont thread into it.
  7. yeah thats how im adjusting it. thanks thats a good idea
  8. I just finished my build and everything went smooth and came together like it should until i got to the clutch. when i dial the clutch in to where it needs to be the pancake bearings hits my clutch cover and pushes it out. if i try dialing my pancake in to where it doesnt hit the clutch doesnt engage so wtf, any ideas?
  9. shee23
    Pismo
    Man Pismo is a cool ass place to go ride I mean there aren't very many places u can camp right on the beach and then go mobbin in the dunes right from camp so to all the tree huggers tryin to shut it down you can get f%#*ed!!
  10. cool thanks fellas
  11. what bearings do you have to replace if any?? i'm replacing all the seals and gaskets but not sure if i need new crank bearings or what all i need to replace.
  12. o..well i cant figure out why my coolant is leaking into my motor oil. any ideas??
  13. How do you know if the washer on your water pump is on backwards, I heard this will cause it to not have the right seal.
  14. cool that helps allot thanks
  15. any ideas would help
  16. Im replacing second gear in my transmission but since I already have the cases apart I want to replace everything I need to. So what is the best way to tell if my crank bearings are bad, my shift forks, and all my other gears. thanks fellas
  17. bump for a great deal wish I had the cash
  18. what gearing and paddles are all of you running on your duners. all mods in my sig
  19. Its just my opinion but i built a 68mm stock stroke cub and didnt like it, I would go 4 mil if your doin a cub.
  20. I forgot to mention sometimes on that metal stud/hose there is a rubber gasket around it and that can get pinched in there and not create a good seal. so when u take the cover off make sure that o ring is on nice and good. also when putting it back together run some oil around that hose so it slips on with no troubles
  21. I just went through this with my bike. I had to pull my clutch cover and the hose that runs from the water pump to the outside of the case was loose in there so i put some sealant around it and tapped it in to where it was supposed to be. no more leak so far. hope this helps
