4strokekilla1987 Posted April 21, 2009 Report Posted April 21, 2009 (edited) ok guys sorry for asking so many damn questions on here but what do u guys think the top speed of a bike with this setup will be 4 mil cub with drag port 4mil crank shave head 35pwk pods +4 timing cpi smallbore vforce 2 68mm pistons 17/39 gearing Edited April 21, 2009 by 4strokekilla1987 Quote
4strokekilla1987 Posted April 21, 2009 Author Report Posted April 21, 2009 cub with a shaved head? yea i shave the stock head for now Quote
tt_bansheerida Posted April 21, 2009 Report Posted April 21, 2009 ok guys sorry for asking so many damn questions on here but what do u guys think the top speed of a bike with this setup will be 4 mil cub with drag port 4mil crank shave head 35pwk pods +4 timing cpi smallbore vforce 2 68mm pistons 17/39 gearing i run a 16 38 i hit around 70 -85 mph on a 1/2 mile oval topped out your bike 95- 100 mph your top speed is mostly gearing your motor can change your mph speed mostly rpm's the more power the bike has the faster the bike will pick up and go when you find out post some numbers up Quote
J-Madd Posted April 21, 2009 Report Posted April 21, 2009 Tire size? There's a gearing calculator somewhere that will speed vs. rpms. Find it, then determine what rpms you think that motor will pull in top gear, with your gearing and tire size. Quote
tony cub Posted April 22, 2009 Report Posted April 22, 2009 ok guys sorry for asking so many damn questions on here but what do u guys think the top speed of a bike with this setup will be 4 mil cub with drag port 4mil crank shave head 35pwk pods +4 timing cpi smallbore vforce 2 68mm pistons 17/39 gearing yo,that last pic on your sig looks like it was taken at one of my friends house..is this that cub motor laz is building,but hasnt finished cause of the wreck??? Quote
4strokekilla1987 Posted April 22, 2009 Author Report Posted April 22, 2009 yo,that last pic on your sig looks like it was taken at one of my friends house..is this that cub motor laz is building,but hasnt finished cause of the wreck??? yea bro that will be it Quote
00tbanshee Posted April 22, 2009 Report Posted April 22, 2009 there is alot to play into the facter,but over 100mph is not out of the question at all! Quote
wacko2000 Posted April 22, 2009 Report Posted April 22, 2009 http://home.earthlink.net/~gellett/banshee.htm Quote
drap660 Posted April 24, 2009 Report Posted April 24, 2009 (edited) I have a stock cyl, 4mill crank with stock carbs that does 110mph on 16/38 gearing. So you should be atleast over 110 Edited April 24, 2009 by drap660 Quote
tony cub Posted April 24, 2009 Report Posted April 24, 2009 I have a stock cyl, 4mill crank with stock carbs that does 110mph on 16/38 gearing. So you should be atleast over 110 your talking about top out right?cause i know your not going to see that from your set up in the 1/4...... Quote
J-Madd Posted April 24, 2009 Report Posted April 24, 2009 I have a stock cyl, 4mill crank with stock carbs that does 110mph on 16/38 gearing. So you should be atleast over 110 You're either running some tall ass tires, or rapping the engine to an unobtainable rpm, according to the link above. Quote
drap660 Posted April 24, 2009 Report Posted April 24, 2009 (edited) Yea Tony thats top end which is maybe 20 feet after the 1/4 mile. Tony, you saw the video of the 1/4 mile pass at 104 and no its not being raped like the other guy said. Bike has stock tires. So if the OP sets it up right for top end he should get 110 in the 1/4 Heres a pic of the bike Here is a pic of my stalker on the 110 run Video of 1/4 pass Edited April 24, 2009 by drap660 Quote
tony cub Posted April 24, 2009 Report Posted April 24, 2009 You're either running some tall ass tires, or rapping the engine to an unobtainable rpm, according to the link above. x2 Quote
