bama boy Posted April 15, 2009 Report Share Posted April 15, 2009 I need some info please. Just had my cylinders bored out and put new pistons and rings in. Got it all together and it fired right up. Took it easy for a while to seat the rings. Everything seemed to be fine. Went out today for a short ride. Now the right side smokes really bad. The exhaust is extremely hot coming out of the right side. Left side is fine. Im about 2000ft. above. Running 280 mains and 30 pilots. +4 timing key, fmf gold series pipes, k&n filter with no airbox. Can anyone tell me why the right side would smoke so bad and be so much hotter exhaust than the left? The guy i bought it from had a 25 pilot in the right side and a 30 pilot in the left. I just need some good help on this before i smoke my top end again and have to tear it all down again. PLEASE HELP GUYS?? Thanks Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 15, 2009 Report Share Posted April 15, 2009 both carbs should have the same size jets.How do the plugs look?-Make sure you have no leaks on the intakes. Quote Link to comment Share on other sites More sharing options...
bama boy Posted April 15, 2009 Author Report Share Posted April 15, 2009 No leaks. I took my time putting everything back together. Do you have any idea why it was fine yesterday and now it has the hot smoke on the right side? I think im ok on jetting. Its just goofy. What is the worst case if i just run it as is? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 15, 2009 Report Share Posted April 15, 2009 how's the plugs look? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 15, 2009 Report Share Posted April 15, 2009 is the smoke white or black? Quote Link to comment Share on other sites More sharing options...
bama boy Posted April 15, 2009 Author Report Share Posted April 15, 2009 Plugs are a dark brown. Smoke is white or a bluish. Like really rich. I mix 32:1. Quote Link to comment Share on other sites More sharing options...
bama boy Posted April 16, 2009 Author Report Share Posted April 16, 2009 Anyone else have some info for me? It would help me out alot!! Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted April 16, 2009 Report Share Posted April 16, 2009 you still got the mismatched pilots in there? it needs one or the other 25 or 30. probably needs a 25 or 27.5 if you asked me. Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 16, 2009 Report Share Posted April 16, 2009 you have white smoke coming out of your right pipe? Quote Link to comment Share on other sites More sharing options...
bama boy Posted April 16, 2009 Author Report Share Posted April 16, 2009 Yes its white but doesnt smell like coolant. Is it possible for one side to run richer than the other? If so how do i fix that? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 16, 2009 Report Share Posted April 16, 2009 you need to make sure your carbs are synced.Hopefully you dont have a seal or gasket leaking. Quote Link to comment Share on other sites More sharing options...
bama boy Posted April 16, 2009 Author Report Share Posted April 16, 2009 Everything as far as gaskets and seals seem fine no visibale leaks. Carbs are synced. I still have the dreaded tors on the carbs but they are not hooked up. Is there any way to adjust the idle? Can u still use the big knob on the tors to adjust idle? I can somewhat adjust it but its hard to get them even. Quote Link to comment Share on other sites More sharing options...
