87sheerips Posted April 13, 2009 Report Posted April 13, 2009 I forget of the coil needs to ground here or not. A simple yes/no would be great! Thanks guys. -JD Quote
2001Stroker Posted April 13, 2009 Report Posted April 13, 2009 Yes. I just had to do that last night to make mine fire. Don't forget the ground wire that goes to the mounting bolt. Quote
87sheerips Posted April 13, 2009 Author Report Posted April 13, 2009 Yes. I just had to do that last night to make mine fire. Don't forget the ground wire that goes to the mounting bolt. the cdi ground your talkin bout, right? So 3 spots total need to be ground. 2 tabs for coil, one for cdi ground wire. Quote
magz Posted April 13, 2009 Report Posted April 13, 2009 the cdi ground your talkin bout, right? So 3 spots total need to be ground. 2 tabs for coil, one for cdi ground wire. i didnt do mine, but i did run a tap through every hole after going through the powder coaters. and after i ran the tap i put a small wire brush on my dremmel and ran it through each hole. havent had a grounding problem at all. Quote
2001Stroker Posted April 13, 2009 Report Posted April 13, 2009 the cdi ground your talkin bout, right? So 3 spots total need to be ground. 2 tabs for coil, one for cdi ground wire. Yea, sorry. I moved all my electronics up behind the radiator. I grounded my CDI through the bolt hole for the coil. But, yes. You got it right. Quote
AKheathen Posted April 13, 2009 Report Posted April 13, 2009 A simple yes/no would be great!-JD yes/no Quote
