lt1bird Posted April 5, 2009 Report Posted April 5, 2009 (edited) Well I finally started the 535 i built over the winter...from scratch..... Started up pretty quick... Lots of smoke probably from the oil I pourded on the cank bearings etc.... Seems pretty good so far.... Whats the best break in process? Trinity says run it for 3 minutes...let it cool, retorque heads and cyls....top off radiator...they say do that 3 times then ride it gently. What about the engine case bolts? Do any of you retorque them after break in?? I will check the timing after the third start cycle and adjust it....to 17degrees Anyone have any other sugsetions? Oh, here is a pic of the final project: Thanks for all the help by many forum folks... Edited April 5, 2009 by lt1bird Quote
Blewbyu Posted April 5, 2009 Report Posted April 5, 2009 Well I finally started the 535 i built over the winter...from scratch..... Started up pretty quick... Lots of smoke probably from the oil I pourded on the cank bearings etc.... Seems pretty good so far.... Whats the best break in process? Trinity says run it for 3 minutes...let it cool, retorque heads and cyls....top off radiator...they say do that 3 times then ride it gently. What about the engine case bolts? Do any of you retorque them after break in?? I will check the timing after the third start cycle and adjust it....to 17degrees Anyone have any other sugsetions? Oh, here is a pic of the final project: Thanks for all the help by many forum folks... Holy shit, that's neat. I had no idea you were putting the motor in a streetbike. But as far as the break in process that's about right. Your putting the timing at 17 degrees? I don't retorque the case bolts. Quote
2strokecook Posted April 5, 2009 Report Posted April 5, 2009 that one of a kind. make a video if you can, when ya get to riding it. looks cool. Quote
lt1bird Posted April 5, 2009 Author Report Posted April 5, 2009 definatly will make a on board video Already have the camera......... Ya, it took a while to build it.....the engine was the most fun...always nice working with all new parts! Still, had to modify the block....2.36 streight cut gears you need to custom machine the water pump shaft, clearnce the block, the side cover etc ....the gears are pretty large in dia..... it was all very fun and a learning experince....never tore down a banshee engine before....was similar to my cr500 engine... The timing will be set to 17 degrees at idle...I think the max timing will be 28 degrees.... Im using a ignitech programmable ignition...pretty slick device...hook your laptop up to it and make your curve....very easy to use and real cheap compared to the dyna... I do have a battery though.... Quote
2001Stroker Posted April 5, 2009 Report Posted April 5, 2009 That's fucking hot man. I also thought you were putting it in your Banshee. Looks good. Quote
spike Posted April 6, 2009 Report Posted April 6, 2009 I also tought you where putting it in a banshee frame. But that thing is just amazing. She should be a handfull to ride for sure. Will probably lay a beating on a lot of unsuspecting poeple!! Quote
lt1bird Posted April 6, 2009 Author Report Posted April 6, 2009 Its too funny...I have an aprilia rs250 that i ride on the street.... so many folks do not know what 2 stroke's are...only folks with 2 strokes know the sound The cascade banshee silencers really keep the noise down...the quality on the silencers is awsome! Quote
lt1bird Posted April 6, 2009 Author Report Posted April 6, 2009 I know, sorry about the switch and bait.....if I told folks what I was doing they would tell me Im crazy..... Quote
F.T.W. Banshee Posted April 6, 2009 Report Posted April 6, 2009 That is fuckin sick. Good work. Quote
lt1bird Posted April 6, 2009 Author Report Posted April 6, 2009 From under the steering stem there are some nice beefy holes. I bent some square aluminum tubing. That runs down the center of the radiator on the front. Then there are supports top and bottom rubber mounted. It looks free floating...kinda cool but the whole assembly can be pushed forward toward the front tire to give me plenty of room to work without removing it.... Quote
Titan up Posted April 6, 2009 Report Posted April 6, 2009 Wow thats one of the fuckin coolest things I've seen. Quote
BSHEE400 Posted April 6, 2009 Report Posted April 6, 2009 that thing is gonna haul some ass :thumbsup: Quote
87sheerips Posted April 6, 2009 Report Posted April 6, 2009 WOW, amazing man... I see a magazine article in the near future! :cool: Quote
KEVSWS6 Posted April 6, 2009 Report Posted April 6, 2009 Very nice. What year and model Zuk is that? Who made the pipes? Can we see more pictures? Quote
