mrbigsacks Posted April 3, 2009 Report Share Posted April 3, 2009 I have a 99 and won't start unless I sprayair in card overflow. once it starts runs perfect just won't hold idle. any feedback is appreciated thanks. Quote Link to comment Share on other sites More sharing options...
SD1026 Posted April 8, 2009 Report Share Posted April 8, 2009 I have a 99 and won't start unless I sprayair in card overflow. once it starts runs perfect just won't hold idle. any feedback is appreciated thanks. I heard that if ur bike idols for 5 min your piolet is good try a larger piolet jet. I'm at sea level and have 5 1/2 turns out on my idol screw. Rinnin stock carbs Quote Link to comment Share on other sites More sharing options...
black sunshine Posted April 8, 2009 Report Share Posted April 8, 2009 Would you be able to give your carbs a good cleaning? What size pilot jet? Turns out on the airscrew? Compression test? Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted April 8, 2009 Report Share Posted April 8, 2009 Would you be able to give your carbs a good cleaning? What size pilot jet? Turns out on the airscrew? Compression test? Make sure you clean your carbs. and try to adjust the carbs, just play aound with them. make sure they sit at the same hight and make sure they move at the same time. Quote Link to comment Share on other sites More sharing options...
xXBANSHEE_KILLAXx Posted April 9, 2009 Report Share Posted April 9, 2009 I have a 99 and won't start unless I sprayair in card overflow. once it starts runs perfect just won't hold idle. any feedback is appreciated thanks. Did u check your idle screw?? if you dont have one like me then your idle screw is at the throttle cable. Mine had the same thing except my jetting was off but other than that same problem Quote Link to comment Share on other sites More sharing options...
