Corndiddly5885
Everything posted by Corndiddly5885
  1. I was wondering what kind of airfilter would best fit rough trail with once in awhile mudding. i just rebuilt my engine and forgot to order a new airfilter cuz it was bad. i had around 2 or 3 hours on it now i have to rebuild it again so i need the best airfilter i can get for around 80 bucks.
  2. wow wat a friend lol
  3. i figured that out after it shut off lol
  4. wen i pulled the spark plug wires it shut off. and it anit running lean the spark plugs are not white at all. there blackish
  5. alright thanks. anybody know about the reeds and reed spacers.
  6. i dont see y low gas could keep it from not shuting off wen i hit the kill switch and turn off the key
  7. i took the head off and it was running rich. i took off the cylinders and i have a bad ring on the left which was at 100 psi. i had plenty of gas in it around 1/4 tank. wen i get it fixed i will do a leak down test. before i torn it down i drove it like an hour and i didnt have the problem but its still bloging. the reeds didnt look the best. so you guys think by putting new reeds and reed spacers it might get rid of some of the blogging?
  8. i know its not running to lean. it could be a air leak. my compression is bad. 100 left side 122 right side. im taking the heads off tonite ill look around in there
  9. Yesterday i was riding and my banshee started to blog and then i stop to check it out and it started to rev high. it soon pinned and i turn off the key and it didnt shut off or wen i hit the killo switch. what could be wrong with it
  10. Corndiddly5885
    arms
    I heard wicked were good and they have a good price to them too
  11. Make sure you clean your carbs. and try to adjust the carbs, just play aound with them. make sure they sit at the same hight and make sure they move at the same time.
  12. thats the same thing that happen to me is that the ebrake got f'd up.i just to it off cuz i never use it.
  13. i am pretty sure too that stock shocks are 14.5 i am riding on 13.5 KYB's and i hate them its to low
  14. alright cool i am just looking around for some good a-arms and shocks to buy and then i will defently buy those wen i get the a-arms.
  15. o so u can put big shocks on. alright cool thanks alot
  16. were can i get the spacers? i know i have seen them before but i cant remember were i did. and witht the yfz a-arms how long of a shock can i put on?
  17. now if i just get the yfz shocks, does it make a big difference from getting both shocks and a-arms?
  18. that anit to bad. are they easier to install?
  19. Hi i was wondering how much it cost to buy used YFZ a-arms and shocks. I have been looking around alot and alot of people say that the YFZ a-rms and shocks do a pretty good job
  20. alright thanks. they any good or no?
  21. Are those good at all? cuz i can only find them for cars.
  22. they are just a warning sticker. but i look all around it and i found the brand KYB
  23. ya any ideas how to find out with out calling the guy who put them on?
  24. alright they must have put a different spring on cuz they are way different
  25. alright thanks. so that website you showed me with the add on rezzies wouldnt work cuz i would have to get work done to the inside?
