4strokekilla1987 Posted April 1, 2009 Report Posted April 1, 2009 i have 98 banshee and everytime i run it drag my coolant leaks out of the radiator bottle excess hose Quote
LS1Inferno Posted April 1, 2009 Report Posted April 1, 2009 well it will only do that if you are overheating. not if you are hot lapping too much even a properly jetted bike will over heat if its only doing it hot you either are running it too hard or are lean. Quote
4strokekilla1987 Posted April 1, 2009 Author Report Posted April 1, 2009 well it will only do that if you are overheating. not if you are hot lapping too much even a properly jetted bike will over heat if its only doing it hot you either are running it too hard or are lean. i think i am running rich my mechanic set it up like that cuz when i first got her i was overreving (not doing that anymore) but do u think that could mess her up that she is runnin rich Quote
LS1Inferno Posted April 1, 2009 Report Posted April 1, 2009 running a little rich isnt bad. too rich is bad it will glaze the cylinders, but rich isnt going to make it overheat. like i said just running a perfect bike too hard and not running her out to cool her off is just as bad a being lean. we have no fans too keep it cool you have to keep moving. if even under normal riding (not racing) she is overheating then you have a bigger issue which could be a from a bad RAD cap (very rare but possible) to a broken waterpump impeller. How does the bike run under so called normal riding conditions? Quote
4strokekilla1987 Posted April 1, 2009 Author Report Posted April 1, 2009 running a little rich isnt bad. too rich is bad it will glaze the cylinders, but rich isnt going to make it overheat. like i said just running a perfect bike too hard and not running her out to cool her off is just as bad a being lean. we have no fans too keep it cool you have to keep moving. if even under normal riding (not racing) she is overheating then you have a bigger issue which could be a from a bad RAD cap (very rare but possible) to a broken waterpump impeller. How does the bike run under so called normal riding conditions? she runs fine sometime she might throw out some fluid though and also when i riding her and the i switch to my brothers his feel like ur riding on air and on mine i feel everybump and motor vibration Quote
LS1Inferno Posted April 1, 2009 Report Posted April 1, 2009 well then she is not fine... and just adjust your suspension and tire pressure. Quote
4strokekilla1987 Posted April 1, 2009 Author Report Posted April 1, 2009 well then she is not fine... and just adjust your suspension and tire pressure. ima take her to the mechanic today thanks Quote
uwenr Posted April 1, 2009 Report Posted April 1, 2009 ima take her to the mechanic today thanks One other thing to look at is a blown head gasket, it will pressurize the cooling system and out the overflow bottle Quote
4strokekilla1987 Posted April 2, 2009 Author Report Posted April 2, 2009 One other thing to look at is a blown head gasket, it will pressurize the cooling system and out the overflow bottle NAW I HAD HER CHECK OUT RADIATOR WAS CLOGED GOT A NEW ONE THANKS Quote
