Keyser Soze Posted April 1, 2009 Report Posted April 1, 2009 It seems the circle do-hickys inside the valve are just about the right size for stock carbs. If the carb is bigger wouldnt it trap air/fuel on the outside of the circlular do-hicky. Here is the thing im talking about Anyone run 34mm carbs with rad valves? Quote
AKheathen Posted April 1, 2009 Report Posted April 1, 2009 you can port stock cages to look like that, and just run the pedals on them Quote
Keyser Soze Posted April 1, 2009 Author Report Posted April 1, 2009 you can port stock cages to look like that, and just run the pedals on them Would like to keep the rad valves if possible Quote
Building my First Posted April 2, 2009 Report Posted April 2, 2009 Just port them if you insist on keeping them. I've heard alot of guys say that stock ported cages are the best. I never heard much about the rad valves, they do look like they could cause some turbulence or restriction. Quote
