tidos76 Posted March 29, 2009 Report Posted March 29, 2009 ace hardware has clear. just make sure you lamp them on REAL GOOD! some people have had them slip off. Quote
wvbanshee1976 Posted March 29, 2009 Report Posted March 29, 2009 ace hardware has clear. just make sure you lamp them on REAL GOOD! some people have had them slip off. go to lowes and get it where i got mine it a snug fit but take a heat gun and heat it then put it on Quote
docjcwatson Posted March 29, 2009 Report Posted March 29, 2009 Make sure your careful about what hoses you use. Radiator hoses are thick for a reason. There is a lot of heat that runs through a cooling system. I would hate to think of what would happen if you used a set of non cooling system hoses. Quote
robert0762 Posted March 30, 2009 Author Report Posted March 30, 2009 ace hardware has clear. just make sure you lamp them on REAL GOOD! some people have had them slip off. go to lowes and get it where i got mine it a snug fit but take a heat gun and heat it then put it on Are you guys talkin about the clear vinyl tubing that the hardware store sells . I thought about that but didnt know if it would stand up to the heat Quote
tidos76 Posted March 30, 2009 Report Posted March 30, 2009 get the hose with the pvc braiding in it. on the tight fitting spots hot it under some HOT water for about 2-3min, it will go on easy as pie Quote
skinindustries Posted March 30, 2009 Report Posted March 30, 2009 How hot does a cooling system run? i was thinking about 220-240? it doesnt run hotter then a car does it? What do you guy think about those inline coolent cooler things. Quote
jbooker82 Posted March 30, 2009 Report Posted March 30, 2009 How hot does a cooling system run? i was thinking about 220-240? it doesnt run hotter then a car does it? What do you guy think about those inline coolent cooler things. Since the banshee doesnt have a thermostat it is all over the place in running temps. I have a Prodesign radiator and when it is cold out mine runs from 140 deg to 170 deg with the temp measured right at the outlet in the front of the head. When it is hot out it runs from 190-210 deg. Quote
jbooker82 Posted March 30, 2009 Report Posted March 30, 2009 get the hose with the pvc braiding in it. on the tight fitting spots hot it under some HOT water for about 2-3min, it will go on easy as pie And that is the same reason why I wouldnt run them. When the bashee gets hot they become super soft and will slip off or blow. Quote
liveordie72089 Posted April 2, 2009 Report Posted April 2, 2009 Yeah I just got mine from lowes but I don't know if it is going to work out good. It says it only can handle 70 degrees??? and the pressure is low also. Quote
