johstoncounty banshee Posted March 19, 2009 Report Posted March 19, 2009 where can i find a 30mm allen wrench or socket to take off the steering stem bearing retainer? Quote
04chase Posted March 19, 2009 Report Posted March 19, 2009 go buy a bolt that is the same size and throw a nut or two on it and turn it off or weld an old 1/2 socket to the bolt. Quote
johstoncounty banshee Posted March 19, 2009 Author Report Posted March 19, 2009 I tried a bolt it twisted i gues i need a better grade bolt its 30mm. Quote
boneyardbanshee. Posted March 19, 2009 Report Posted March 19, 2009 you twisted the bolt? damn Hercules, get the torches out. Quote
johstoncounty banshee Posted March 19, 2009 Author Report Posted March 19, 2009 With a 4 ft pipe help Quote
johstoncounty banshee Posted March 20, 2009 Author Report Posted March 20, 2009 I finally got the dam retainer off with heat and 3/4 impact with 30mm cat bolt. Quote
fck55mph Posted March 20, 2009 Report Posted March 20, 2009 Shit! mine has a little slop in it too...this is really making me wanna do mine now!! Fuck!! Quote
johstoncounty banshee Posted March 21, 2009 Author Report Posted March 21, 2009 Shit! mine has a little slop in it too...this is really making me wanna do mine now!! Fuck!! Oh try it its real fun Quote
Darkblade Posted April 4, 2014 Report Posted April 4, 2014 I'm having a problem getting the Bering retainer for the steering stem out I made a tool with a 30mm bolt and heated it with a torch the hit it with an impact driver but it wouldn't budge I need help ASAP thanks Quote
Nieskes Posted April 4, 2014 Report Posted April 4, 2014 Is it rusted? Are you turning it the correct way? Quote
Starwriter Posted April 4, 2014 Report Posted April 4, 2014 I made a tool with a 30mm bolt and heated it with a torch the hit it with an impact driver but it wouldn't budge Impact driver? The kind you smack with a hammer? That's not gonna do it. Or do you mean an air impact gun? That should do it, unless you bought it at Harbor Freight. I always just use a 1/2" drive ratchet or breaker bar. Quote
Darkblade Posted April 4, 2014 Report Posted April 4, 2014 I mean air impact gun one made by craftsmen the other is air stream set at 120 psi and I used an acetylene torch and I let it soak in wd40 pb blaster but it's still stuck Quote
Darkblade Posted April 4, 2014 Report Posted April 4, 2014 Yea I'm doing a complete restoration and it is the only thing holding me up I have a new one on its way but I need to get the old one out by any way possible including cutting it out if I have to Quote
