anyone rebuild their crank? just wondering if it is worthrebuilding it, or replace it. Is it a difficult task? nothing broken yet, but one bearing is a bit rough and some play in a rod.
thanks for any input
if its stock it not really worth it. it would be cheaper to find a good used one on here. they are easy to find pretty cheap with low hours. good luck.
If you have a stroker it is way worth it, make sure you have it trued and welded or rewelded when you are done. :cool:
Crank bearings OEM are like 30 I think, plus machine labor. Plus true and weld (or reweld)
You can generally find a used one in perfect shape for 75 to 150 bucks, sometimes even trued and welded.
