i am running a dunable overide, so 6th gear is history, what gearing are you guys using?? could i go with the older style stock hub to use a smaller rear sprocket?? whats the biggest fron sprocket i can use on the front (i have a case saver).. 1st gear is geared pretty low, and 5th not enough.. i think i currently have 14/42.. not too sure.. help a brotha out.. lol
16-41 is a good high gear combo. with 22s it even better
hard to pull that at the dunes
15-41 works decent with that dirt and sand 22s
20s in dirt i would say 16-41
depends on your power level
