sheerider1026 Posted March 18, 2009 Report Posted March 18, 2009 i am running a dunable overide, so 6th gear is history, what gearing are you guys using?? could i go with the older style stock hub to use a smaller rear sprocket?? whats the biggest fron sprocket i can use on the front (i have a case saver).. 1st gear is geared pretty low, and 5th not enough.. i think i currently have 14/42.. not too sure.. help a brotha out.. lol Quote
locogato11283 Posted March 18, 2009 Report Posted March 18, 2009 1-5 right?? use this gearing chart. http://home.earthlink.net/~gellett/banshee.htm figure out what you were running when taking off in second.. then match up the gearing so that youre getting about the same speed out of first. Quote
dragbanshee Posted March 18, 2009 Report Posted March 18, 2009 You may allready have this, play around with it, it may help. http://home.earthlink.net/~gellett/banshee.htm You got a 40 tooth? I would try that. Quote
wesw Posted March 18, 2009 Report Posted March 18, 2009 16-41 is a good high gear combo. with 22s it even better hard to pull that at the dunes 15-41 works decent with that dirt and sand 22s 20s in dirt i would say 16-41 depends on your power level Quote
sheerider1026 Posted March 18, 2009 Author Report Posted March 18, 2009 its a 392 cub, so it has plenty of power.. i may go with a 15-40 and a 22" tire.. and thanks for the help guys.. with a little gearing this thing will haul ass in a hurry. Quote
