Im thinking about rebuilding top half, What would you think the average cost would be if I had some one do it? What would you suggest in parts, motor is stock now. money is kinda limited
Edited by steeler2169
as far as parts go, it depends on what kind of riding you do. and there is no such thing as an "average cost" of a rebuild. and if $$ is tight, you might not want to rebuild it at all. horse power is like a drug! you always want more... and the more HP you want, the more $$ you are going to have to spend.
however if you really want to rebuild it, let us know what style of riding you do, and how much you are willing to spend. that way we can help you out with part suggestions.
you would save alot of money if you did your own wrenching. the top end is easy!
Edited by tapout94
The reason why I ask is because my right cylinder fouled the plug. Then last night i started it for a sec. and I heard A nock. And its smoking not like a blown motor smoke though. What is the comp. suppose to be at Ill check it tonight.
generally 110 to 130 is ideal.
100 is somewhat ok, anything lower then 100 is in need of a rebuild for stock motor. some have ran with 90 psi but, i generally only let my cylinders drop about 10-15 from the original PSI it put out.
