bike will have passion dune ported cylinders, PT hi revs, raised compression and reeds, adv. timing; otherwise stock. Swinger is stock as well.
Found a really nice set of 21x12x8 superlight Hauler 7 paddle Extremes... thinking of picking them up to use as my dune and play drag tires. They should hook good enough but still provide enough slip to not throw me over and let me keep my revs when duning....
thoughts?
thoughts?
correct.
thoughts?
Those should be fine on that stock arm. :cool:
damn noob.. thought you been around the block a few times?? :biggrin:
yea, no chit right.... i keep second guessing my thoughts so why not double check... :biggrin:
Edited by sredish
I run 8 pads and have had great luck with them. I dont think 7 will be enough for you
Are your regular haulers or extremes? The ex hook considerably better than reg haulers do..
RIPPEN
thoughts?
super lights are thin unless its no tree or rocks or whatever iw ould be lil leary of duning with them.
no saying it cant be done but.
rmatv sells decent haulers would suggest 8-9 paddles.
I have a pair of Padla Brats comp cut 8 paddles for my one Honda and a pair of superlight 8 paddle regs. for my other Honda. I'm very familiar with superlight and comp cut paddles. The lighter the better.
i run ultra light haulers 9 paddles on a stock swinger and i dont mind it. hooks real hard
I'm getting a set of rear hubs Honda pattern for the Banshee and this way I can swap across all three sets... see which one works good on each. I know my favorite paddles period are Padla Brats... those suckers are bad to the bone, but for 4 bills, i'm just not feelin another set right now.
I know I'm going to get lambasted here, because I've always seemed to run more paddles than anyone else, but... I ran regular 8 paddle haulers up until the end of last season when I got 9 paddle extremes. I got the 9's because I am working over a set of cylinders right now, but I am running them on my stock cylinders right now. Now, when I'm dragging I can't launch in 2nd and it is a definite handful on big climbs on the stock arm, but a lot can be said for gearing and body position on the bike. Personally, I would run a minimum of 8 paddle extremes, but like I said, I seem to run way more paddles than most for whatever reason. :shrug:
I think some 7 extremes will make a nice combo dune/playdrag tire. I have a set of 21/12/8 8 paddle reg haulers and they are a nice all around tire on a stock arm. If its a good price snatch em up, you can always turn them on here.
